Nous avons un nouveau gadget dans la gamme Powerbox
PowerBox BaseLog
Features:
* Dual regulated output voltage
* User-selectable output voltage of 5.9 V or 7.4 V, software-variable using the SensorSwitch
* Informative graphic OLED screen with a resolution of 128 x 64 pixels
* Facility for connecting MPX and Spektrum downlink bus systems
* Direct transmission of both batteries' voltage and capacity to the transmitter
* Voltage display for each battery
* Residual capacity display for both batteries
* Minimum value memory for both batteries
* Large heat-sink area for high regulator performance
* Supports all currently used battery types: LiPo, NiMH / NiCd, LiFePo
* Suppression of possible servo feedback currents
* Various patch-leads (MPX / JR / Futaba, MPX / MPX) available, allowing the use of all receiver types
Specifications:
* Operating voltage: 4.0 Volt to 9.0 Volt
* Power supply:
2 x 2-cell LiPo battery, 7.4 Volt,
2 x 5-cell NiCd or NiMH batteries,
2 x 2-cell LiFePo battery (A123)
* Current drain:
Switched on: approx. 85 mA
Switched off: approx. 10 µA
* Dropout voltage: approx. 0.25 V
* Max. receiver and 2 x 10 A (stabilised), according to cooling measures
* Servo / receiver current:
Peak 2 x 20 A
* OLED screen resolution: 128x64 pixels
* Bus systems: Spektrum, Multiplex
* Temperature range: -30°C to +75°C
* Dimensions:
93 x 67 x 19 mm (incl. base plate)
* Weight: 88 g
* SensorSwitch: 15 g
* EMV approval: EN 55014-1:2006
* CE approval: 2004/108/EG
* Registered design: DE 203 13 420.6
This battery backer fulfils the EMV protective requirements, EN 55014-1:2006 with certificate dated 16 January 2010. EMC approval 2004/108/EG.
Preis € 169,-
(Patch wire MPX/JR/Futaba)incl. VAT
plus carriage costs
Preis € 169,-
(Patch wire MPX/MPX)incl. VAT
plus carriage costs
En plus je suis nul en anglais donc je ne vous direz pas à quoi il sert
